OzXFR
close
- Join DateFeb 2014
- LocationAdelaide, South Australia
Liked:3,658 Times in 2,688 Posts
Quote:
Both are 90mm x 30mm, but the difference is the centre bore. Either 12mm or 17mm.
I'm thinking 12mm is too small. That would be an M10 bolt.
Can you confirm the bolt is a M16? That would make the 17mm a perfect fit.
OK, another measurement with my trusty rule and Mark 1 Eyeball measurethingy gives me a centre bore of 18 mm.Originally Posted by RochaSDS
I found 2 options on the Dayco site.Both are 90mm x 30mm, but the difference is the centre bore. Either 12mm or 17mm.
No idea if the bolt is an M16 or not.
Hey OzXFR,
I see you've got the Eurotoys crankshaft pulley. If I'm not mistaken that on is 11.8% larger than OEM.
The one I'm having machined is closer to the Paramount / Viezu pulley which is 15% larger.
What size belt did they supply you with?
I haven't bought anything from Viezu / Paramount, but I've been trying to get information from them and they've stopped responding, understandably.
Does anyone out there have the outer diameter of the Viezu / Paramount upgraded crankshaft pulley?
They say it's 15% larger, but I'd like to get the dimension to work with and alter my drawings.
OzXFR
close
- Join DateFeb 2014
Sorry for the late reply, I missed your post.Originally Posted by RochaSDS
Hey OzXFR,I see you've got the Eurotoys crankshaft pulley. If I'm not mistaken that on is 11.8% larger than OEM.
Eurotoys sent me a Gates K080570 belt which is 1467 mm long.
Does anyone out there have the outer diameter of the Viezu / Paramount upgraded crankshaft pulley?They say it's 15% larger, but I'd like to get the dimension to work with and alter my drawings.
Anyone???
