DIY Crankshaft/SC Pulley Upgrade
Old Jan 24, 2023 | 05:20 AM
OzXFR's Avatar
Originally Posted by RochaSDS
I found 2 options on the Dayco site.
Both are 90mm x 30mm, but the difference is the centre bore. Either 12mm or 17mm.
I'm thinking 12mm is too small. That would be an M10 bolt.
Can you confirm the bolt is a M16? That would make the 17mm a perfect fit.
OK, another measurement with my trusty rule and Mark 1 Eyeball measurethingy gives me a centre bore of 18 mm.
No idea if the bolt is an M16 or not.
Old Jan 24, 2023 | 05:38 AM
RochaSDS's Avatar
That's exactly it.
The 18mm (or 17mm) is perfect for the M16 bolt.
Old Jan 24, 2023 | 08:21 AM
RochaSDS's Avatar
Hey OzXFR,
I see you've got the Eurotoys crankshaft pulley. If I'm not mistaken that on is 11.8% larger than OEM.
The one I'm having machined is closer to the Paramount / Viezu pulley which is 15% larger.
What size belt did they supply you with?
I haven't bought anything from Viezu / Paramount, but I've been trying to get information from them and they've stopped responding, understandably.
Old Feb 9, 2023 | 03:58 AM
RochaSDS's Avatar
Does anyone out there have the outer diameter of the Viezu / Paramount upgraded crankshaft pulley?
They say it's 15% larger, but I'd like to get the dimension to work with and alter my drawings.
Old Feb 9, 2023 | 04:58 AM
OzXFR's Avatar
Hey OzXFR,
Sorry for the late reply, I missed your post.
Eurotoys sent me a Gates K080570 belt which is 1467 mm long.
Old Mar 27, 2023 | 05:28 AM
RochaSDS's Avatar
Anyone???
akenation
Nov 28, 2020 08:51 PM
tlim52
XF (X260)
Jul 16, 2017 09:14 PM
craig 01
Dec 19, 2011 04:16 AM
mystype04
Dec 26, 2010 01:53 AM
