Do door modules need coding? - 2012 XF
Old Feb 10, 2026 | 06:42 PM
bonanza's Avatar
Default Do door modules need coding? - 2012 XF
Hello,
I have a 2012 XF Portfolio and I just changed the passenger side window regulator because I was having trouble putting the window up. It would go up a bit and then stop, after about a minute or so, I could continue to put the window up.
After replacing the regulator, It works better but still stops mid travel, I have to wait a minute or so to continue to put the window up.
I'm assuming this is probably a door module issue with either the torque sensing or a transistor that drives the power for the motor.
I'd like to know, if I buy a used door module will the module need to be coded to the car?
Regards,
Bonanza
Old Feb 11, 2026 | 04:39 AM
webb 72's Avatar
Originally Posted by bonanza
Hello,
Regards,
Bonanza
The last time this happened to me it got coded using SDD, Lucky i have a buddy that takes care of any issues using the jag software which is a bonus
hope your issue works out ok
Malc
evanscornelius
General Tech Help
Jun 10, 2024 04:52 PM
Mad Hatter
Aug 22, 2019 12:52 PM
PJ704
Jun 7, 2019 02:46 PM
Starion
May 7, 2018 09:47 AM
jimlombardi
Dec 15, 2012 11:12 AM
