Door Wood Veneer Removal
Old Nov 3, 2020 | 06:00 PM
yongstevekim's Avatar
Default Door Wood Veneer Removal
This might be a dumb question, but does the door trim need to be removed in order to remove the wood veneer attached? 2012 XF Base. I am trying to either replace it or wrap it.
Old Nov 3, 2020 | 07:43 PM
davetibbs's Avatar
Yes - the veneer is held in place by metal clips on the back of the door trim, and you'll definitely need to remove the trim to remove these clips.
Old Nov 4, 2020 | 01:18 PM
That's great. Thanks for the quick reply. No wonder I couldn't find any videos on removing the veneer only, as the door trim needs to be remove. Tons of videos on door trim removal though. Makes sense now. I think I will just wrap over it without removing the trim as I don't want to loosen anything inside the door that might make weird noises. Thank!
TheBaltimoron
Jul 10, 2019 04:33 PM
TheBoy
Jun 15, 2017 11:17 AM
Ntimd8
Apr 7, 2016 07:00 PM
luc
Jan 8, 2012 11:34 AM
wdmoreton
Mar 17, 2008 10:46 PM
