Drive Shaft Play
Old Apr 2, 2018 | 06:14 PM
BlckCat's Avatar
Default Drive Shaft Play
My 2013 XF AWD has a quarter inch, maybe more, of in-out slop in the front drive shafts (cv joints). Is this normal? The rears have no play at all.
I have always had too much vibration through the steering wheel on the OEM 20s so I finally bought a set of 19s for a smoother ride. However now I have a large shake back and forth in the steering wheel above 45 mph. They scored excellent on the road force balance (2 and 4) so the shop said I should ask for a new set of front tires from Pirelli since there must be something wrong they can't see. Before I go through that I checked all of the suspension and the drive shafts are the only thing I can come up with.
Old Apr 2, 2018 | 10:51 PM
lotusespritse's Avatar
Did you see my post on the other thread??
Old Apr 3, 2018 | 04:51 AM
BlckCat's Avatar
Yes I installed them all myself this last time. I just need to know if the front drive shaft play is normal before I send the tires back.
Bogbrush
Feb 5, 2016 07:03 AM
cyber3d
Jan 18, 2016 04:02 PM
04Sport
Apr 11, 2015 10:16 PM
o1xjr
Apr 16, 2014 10:09 AM
penguin
Mar 18, 2013 12:10 PM
