Dynamic mode + manual shifting = red triangle displayed on infotainment system
past couple times ive had a chance to really let the cat loose, id put it in dynamic mode, put the transmission in sport and as soon as i start shifting manually, a red hazard triangle shows up on my infotainment system....but nothing on my dash.
when I click the triangle, it just says "see message center"....but nothing displays on the dash. no warning lights, no CEL, absolutely fine.
any ideas?
any ideas?
This is normal operation, nothing to be worried about.
For some strange reason JLR saw fit to "warn" you that you are in Dynamic and S, as if you didn't already know this!
Well this is because when you are in dynamic and S at the same and then use the paddles to manually shift the car will hold the gear until you tell it to move out of it.
You can burn up the transmission if you lets say, put it in 2nd and then went to 120mph.
