Engine codes
Old Nov 22, 2019 | 12:25 PM
Willie Alfaro Mora's Avatar
Default Engine codes
Hello gentlemen,
I have a 2013 Jaguar XF 3.0 AWD. This is my first Jaguar and I got it from an auction in MN. Recently my check engine light has come on and the codes are:
P0164: O2 sensor - circuit high voltage Bank 2 - sensor 3
P0162: O2 sensor - circuit Bank 2 - sensor 3
P0061: Heated O2 sensor heater resistance (bank 2, sensor 3)
B1144: Heated steering wheel supply
C1A58: Front right tire pressure sensor and transmitter assembly/ Wheel module
What are these codes, and what should I do about them? Are they something to worry too much about?
Old Nov 25, 2019 | 12:30 PM
pab's Avatar
pab
First off, how is the battery? These cars are very vulnerable to phantom codes that result from a tired battery.
Otherwise O2 sensor failures are common as are problems with the tire pressure monitoring sensors. The O2 sensors will throw a code. There's a separate tire pressure warning light.
The heated steering wheel is the wild card.
Current Hers: '13 Lexus ES350
Current Mine: '15 XF (X250) Portfolio AWD
Jaguar - making mechanics out of customers since 1935
Old Nov 25, 2019 | 01:32 PM
lotusespritse's Avatar
Seems like it's telling you in no uncertain terms that you have a bad O2 sensor.
The steering wheel is probably a bad connection in the column.
The tire sensor is probably a problem with the sensor or the module.
These are not the types of errors you would get with a bad battery.
Cobbler
Oct 16, 2018 10:27 PM
id1207
Dec 17, 2015 08:53 AM
David SD
Jul 6, 2015 04:41 PM
yeldogt
Jul 30, 2010 04:59 PM
hankycbr
Aug 14, 2008 01:37 AM
