Error codes - need help
Old Jun 23, 2022 | 09:15 PM
subtech's Avatar
Default Error codes - need help
Am new here and need help on Jaguar XF 2014 throwing up the error codes below.
B1009-62. Permanent
B102B-67. Intermittent
U3002-81. Intermittent
The car was towed to the shop with no keys so I reprogrammed two keys but after,ignition can’t open. I tried the immobilization method with SDD but not successful and shows on dash, parking brake error.
Any help will be much appreciated..thanks
Old Jun 24, 2022 | 03:00 AM
Here's the extract for this set of codes from the XF Workshop Manual showing possible causes:
Programming new keys as a single task is (usually) straightforward as long as the vehicle is on an independent power supply throughout the procedure but re-programming 'used' keys previously coded to another vehicle is risky.
Old Jun 24, 2022 | 05:17 AM
subtech's Avatar
I programmed new set of keys to the car..Now whenever u press on any of the remote buttons on the key it give you the same error sound u get with the parking brake error..the two error codes that are not able to erase are B1009-62 and U3092-81.Will check the ground and power when I get to work.
Daniele250389
Mar 31, 2024 10:27 AM
panthera999
May 23, 2021 04:24 PM
Oxidizer2k
Dec 31, 2020 02:56 AM
OGUNTOYE
May 11, 2018 09:59 AM
Fermanaghman
Nov 15, 2012 09:01 AM
