European map navigation system for US
Old Jan 23, 2014 | 09:45 AM
avabrantes's Avatar
Question European map navigation system for US
I have a 2012 XF Jaguar purchased in the US.
I have moved with it to Portugal
The US oriented navigation system does not know where it is .
How can I get the European map navigation system and how can I install it?
Old Jan 23, 2014 | 10:03 AM
Welcome to the forum avabrantes,
You will have to replace the US Navigation DVD with the European DVD for Portugal. The European update is a four disc set from Jaguar although there are other 'unofficial' sources.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jan 23, 2014 | 12:27 PM
caviarjag's Avatar
You may need more than disks as regional coding on the CDs may prevent your car from playing them. I would check with the dealer, see if they will let you try out the new disks before you buy them. You may need a software modification to the nav unit.
Old Jan 23, 2014 | 02:47 PM
Jerry S's Avatar
CD or DVD discs are not used by the 2012 Nav system. It is updated via a USB flashdrive. Suggest you contact Jaguar UK or a local dealer to determine what may have to be done, if anything, to make the Nav system compatible for a European update.
Old Jan 23, 2014 | 02:59 PM
Originally Posted by Jerry S
CD or DVD discs are not used by the 2012 Nav system. It is updated via a USB flashdrive. ...............
So it is.
Updates for the earlier DVD system are expensive. This one could need a second mortgage!
Old Jan 23, 2014 | 03:13 PM
Jerry S's Avatar
In the US, an update flashdrive is $300 plus tax the last time I checked.
XF_Hunter
Jan 17, 2018 08:38 PM
timfountain
Sep 17, 2015 05:12 PM
drewlabarbera
Sep 14, 2015 07:46 PM
brgjag
US Midwest
Sep 4, 2015 11:24 AM
