Fluid change questions
Old Nov 12, 2019 | 05:47 PM
TreVoRTasmin's Avatar
Default Fluid change questions
Wifes 13 xf awd 3.0 has around 80k on the odo Figure it is time to refresh the fluids. Tranny it looks like 7 liters of Lifeguard fluid for the 8 speed zf , coolant Jag specific but how much? what have others used for the rear dif and what is the amount needed? Power Steering fluid? Also, I'm pretty out of it on the awd system. Is there a seperate transfer case or front dif? If so what fluid and how much for that? I'm hoping to talk my indie Jag guy into doing it all at once. Have been told the supercharger is a bit of a challenge and that it should be serviced around 100k so I'll hold off another year on that one unless those with more knowledge on the XF has better ideas. Ahy of this overly hard to do like the rear dif on a XK8 or an X-type transfer case? Thanks for the help!
Old Nov 22, 2019 | 02:30 AM
George05's Avatar
Super charged oil should be changed every 50,000 miles
AndrewG
Jul 4, 2018 06:48 AM
Rigsby94
Feb 11, 2013 09:56 AM
Spooky pantz
Dec 21, 2011 07:34 PM
Rob R
Jan 10, 2011 07:28 PM
Vanden Plas
Sep 14, 2008 07:12 PM
