Front Suspension Squeaking
Old May 25, 2016 | 10:57 AM
fastlanz's Avatar
Default Front Suspension Squeaking
Recently developed a really bad squeak from the front struts / suspension. . Any ideas how to fix this? The squeaking goes away temporairily if I spray water on the suspension parts in the front wheel wells.
Thanks.
Old May 25, 2016 | 11:04 AM
NBCat's Avatar
You must first isolate the source of the squeaking noise.
It may be from the upper wishbone arm bushes, which are not sold separately as a service part. It could also be one of the lower suspension bushes or the lower damper bush.
Old May 25, 2016 | 07:39 PM
fastlanz's Avatar
This sounds like it's going to be fun. It's strange in that it takes about 30 minutes before the squeaking kicks in. It started this morning then the car sat all day and in the evening it didn't do it at all until about 30 minutes later. Weird...
Old May 25, 2016 | 10:40 PM
NBCat's Avatar
Try spraying individual bushes with a penetrating oil one at a time until you no longer hear the noise. Once you determine the source, you can replace the item causing the noise without guessing and spending more money.
oldish git
27
Jul 24, 2020 02:05 PM
BobRoy
49
Sep 18, 2016 10:48 AM
iownme
Apr 1, 2016 05:20 AM
xjtom
Mar 31, 2016 04:16 PM
wyxtype
Mar 30, 2016 05:39 AM
