Fuel Filter
Old Jul 18, 2020 | 08:01 PM
Jokerrr's Avatar
Default Fuel Filter
I can’t seem to locate the fuel filter on my 2010 XF 5.0.
Old Jul 19, 2020 | 08:49 AM
clubairth1's Avatar
Community Influencer
DI engine so the only filter is on the pump in the tank.
Not serviceable without replacing the fuel pump in the tank. This is the low pressure pump that feeds the high pressure gear driven fuel pumps used to get the very high DI fuel pressure.
Seems strange to me too! But it's the same with other cars. My wife has a Lincoln MKS with the DI 3.5L ECO Boost Engine. Same thing.
Old Jul 19, 2020 | 09:49 AM
Jokerrr's Avatar
To access it is through the hole in the rear seat, if i replace the pump through that can i also replace the filter or do i hav to drop the tank?
Old Jul 19, 2020 | 12:43 PM
.... or the correct forum.
You have an X250 (2007-2015). This is the forum for X260 (2015 onwards). I've moved your question to X250 forum.
Old Jul 20, 2020 | 12:35 PM
clubairth1's Avatar
You can service everything from the back seat thru the access ports. If you remove the pump assy. the filter is attached. Now again your going to need to shade tree this a bit because you can't get the filter but many fuel pumps come with the same type so it's not a problem to match one up. Can you get the filter/sock separately from your local parts store? You probably can.
Are you aware of the tool needed to remove the locking ring that holds the pump in the tank?
Some have tried with a hammer and screw driver but it can be very tight and I would just get the correct tool to prevent breaking stuff. It's all plastic.
Old Jul 21, 2020 | 05:08 AM
Y..... going to need to shade tree this a bit because you can't get the filter .....
That leads me to wonder WHY Jokerrr wants to find and access the filter. It's NOT a service item.
Old Jul 21, 2020 | 06:18 AM
Jokerrr's Avatar
I was sold a filter at o’reillys, i figured it has never been changed. it’s my first jag and when i looked up the locations it said it was under a tire
billwyatt83
Apr 3, 2020 02:48 PM
mrathell
Jun 28, 2017 05:14 PM
plums
General Tech Help
Apr 2, 2013 07:20 AM
Adam Lueb
Oct 14, 2010 04:11 PM
fastexas
Sep 14, 2009 08:39 PM
