Fuel Gauge diesel
Old Jan 17, 2024 | 12:03 PM
RobJag250's Avatar
Default Fuel Gauge diesel
I have the following problem, i dont see the correct measerment of the tank fuel \diesel.
When i use Keyfob nr 1, there is no problem everything is good, and see correct amount of diesel
But when i use Keyfob nr 2 i see only halve of the value whats inside the tank
is this a problem related to the second Keyfob, or is this problem related to the fuel gauge inside the tank.
for example must i replace the fuel gauge, or can in replace only sender part, or must the second Keyfob be programmed correctly
SJones
Oct 31, 2019 12:20 AM
davidladewig
Jun 12, 2017 09:14 PM
jagnew
Dec 23, 2015 09:17 PM
Acebars
Jul 17, 2014 04:29 AM
Jeronimo770
XK120 XK140 XK150
Apr 16, 2014 12:03 PM
