Fuel injector cleaner
Old Mar 10, 2015 | 10:29 AM
Bigg Will's Avatar
I would say the only way to do a complete fuel system clean on a direct injector car would be to run a can of the cleaner through the gas tank, then SeaFoam style clean the engine (Suck it out of the can with engine vacuum). Then change the oil, and clear the check engine codes.
Old Mar 10, 2015 | 10:31 AM
neogod's Avatar
Originally Posted by oldmots
I meant to say that, as already mentioned, some of the carbon comes from valve overlap when the intake and exhaust valve are open at the same time. Nothing you can do about it, but you can keep the crankcase systems clean and this will help. Dirty oil offgasses all kinds of stunky crud that can stick to valves
The intake and exhaust valves should never be open at the same time, when that happens it's called floating the valves, and usually means something bad is immediately about to happen to your engine.
Old Mar 10, 2015 | 11:05 AM
Bigg Will's Avatar
All modern engines have some valve overlap designed in their cam timing to aid in scavenging (Clearing) the cylinders.
Old Mar 14, 2015 | 05:09 PM
sparkenzap's Avatar
Ah, the magic Seafoam elixir. Pour it in your tank, pour it in your crankcase, suck it into your engine!
Magic stuff, indeed!
Old Mar 30, 2015 | 06:10 PM
neogod's Avatar
I think you're thinking about the CAMS. They have an overlap when switching from the low cam to high cam. I'm not 100% certain, but I'm pretty sure that the valves don't float on purpose.
On another note, I just got my oil changed at this local shop that specializes in Jags. I remember them saying they add an additive the first time I got it done, I looked at my receipt and noticed the additive they add is BG110. I looked them up to see how good they were, this video sold me. Now and forever will I use this in all my vehicles.
Old Mar 30, 2015 | 06:30 PM
plums's Avatar
And what do you think actuates the valves?
There is overlap but overlap is not valve float.
Those are two completely different phenomena and are related
only by the the fact that they are related to valve train components
and cam profile.
In short they are not the same thing.
Old Mar 30, 2015 | 07:50 PM
Gus's Avatar
Gus
You do not need MOA if you are using a good synthetic oil.
Old Mar 31, 2015 | 06:44 AM
  #28
neogod's Avatar
That could be argued, but I would rather spend the extra couple bucks an oil change in hopes it'll save me from spending a couple thousand on fixing engine problems.
Old Nov 18, 2016 | 10:10 AM
Joe1050's Avatar
Originally Posted by Executive
If nothing is wrong with the car, i wouldn't put any type of additives in there. Just use premium/super gasoline in the car and you will be fine.
If I have 2 bad injectors, is it OK to replace only the two injectors,or did I have to replace all 8? Help
Old Nov 18, 2016 | 04:23 PM
  #30
OzXFR's Avatar
Assuming you have a V8, it appears that the injectors must be replaced as a "matched set" on each bank.
So if both your bad injectors are on the same bank you will need one bank of four replacements, but if you have one bad injector on each bank then bad luck you need all eight replaced.
Old Nov 19, 2016 | 03:58 AM
  #31
JagV8's Avatar
The good news is that it's very unlikely you have 2 bad ones! (Or even one.)
Old Nov 19, 2016 | 07:22 AM
  #32
Mikey's Avatar
How did you determine that you have bad injectors? Such an event is almost unheard of.
Old Nov 19, 2016 | 11:44 AM
  #33
Gus's Avatar
Gus
A new thread should be created from post #29.
Old Jul 12, 2020 | 12:04 PM
  #34
Brent Logero's Avatar
Originally Posted by Blackcoog
I was told to run a bottle of that BG 44K cleaner with every fill up. I know that's ridiculous but I may run some through every oil change or once a year. The car was already in for an injector clean that I narrowly escaped paying $300 for, and my car is under warranty. Apparently, it's a common issue on the Jags and running that BG cleaner is the best solution. I usually don't go for the magic bottle solution but everyone swears by this BG cleaner the more I research it. I picked some up off of Ebay for about $20. Not many stores seem to sell it.
For the DI motors you will probably want to run some through the intake to clean out the carbon deposits on the ports and valves. Most DI cars suffer from severe carbon build up on the valves where in the older motors fuel would keep it clean. I read through many posts on the Audi forum that noted the RS4 losing nearly 100hp after the carbon starts building up.
Is BG 44K as Good as Seafoam or Marvel Mystery Oil in a Gas Engine? Let's find out!
https://www.youtube.com/watch?v=tX-h62PUu0o
Does Royal Purple Fuel Max Cleaner Actually Work (with Proof)?
knightofgold
Feb 11, 2016 06:03 PM
ogorir
Jan 18, 2016 10:09 PM
Bigvettefreak
Sep 29, 2015 04:13 PM
ratgawd
Sep 16, 2015 04:15 PM
Bcrary3
Sep 11, 2015 10:36 AM
