Which fuse is only on with the ignition?
Old Sep 18, 2014 | 06:04 PM
aaronn's Avatar
Default Which fuse is only on with the ignition?
I'm looking to hard-wire my dashcam to the passenger footwell fusebox but only want it to get power when the ignition is switched on. I have a 2010 XF-R.
Here are the options from the manual:
F1 - - Not used.
F2 - - Not used.
F3 20A Blue Driver's seat adjustment.
F4 20A Blue Driver's seat adjustment.
F5 - - Not used.
F6 - - Not used.
F7 - - Not used.
F8 20A Blue Front passenger's seat adjustment.
F9 20A Blue Front passenger's seat adjustment.
F10 20A Blue Left-hand rear door controls.
F11 20A Blue Right-hand rear door controls.
F12 - - Not used.
F13 10A Red Steering column adjust.
F14 - - Not used.
F15 - - Not used.
F16 5A Tan Sunblind.
F17 - - Not used.
F18 - - Not used.
F19 - - Not used.
F20 5A Tan Remote control receiver.
F21 5A Tan Foot brake.
F22 5A Tan Electric parking brake.
F23 5A Tan Driver's seat. Audio system. Auto headlamps. Upper centre
console switches.
F24 10A Red Front passenger seat. Electric windows. Mirror adjustment.
F25 20A Yellow Driver's heated/climate seat
F26 15A Blue Trailer power connector. Road pricing system.
F27 20A Yellow Front passenger's heated/climate seat.
F28 15A Blue Auxiliary power socket.
F29 20A Yellow Keyless entry system.
F30 10A Red Air conditioning.
F31 15A Blue Sunroof.
F32 5A Tan Jaguar Smart Key docking station.
F33 5A Tan Diagnostic connector.
F34 5A Tan Instrument pack.
F35 15A Blue Interior lamps.
F36 10A Red Suspension system
Thank you!
Old Nov 11, 2014 | 06:48 PM
aaronn's Avatar
Any guesses?
Old Nov 11, 2014 | 10:51 PM
lotusespritse's Avatar
Do what I did and tap into the the power for the dimming rear view mirror. Plenty of power there for a dash cam that barely uses any amps, and you don't have to run wires from under the dash. Super easy and clean.
It's also switched power.
Old Nov 12, 2014 | 05:14 PM
aaronn's Avatar
That's actually a fantastic idea! Thanks!
aode06
Jul 28, 2023 02:26 PM
hoodun
Nov 20, 2022 02:35 PM
goingjag
Sep 30, 2015 09:27 PM
millertic
Sep 30, 2015 08:11 PM
