Fusible link on battery +ve
Old Sep 14, 2024 | 06:10 PM
POD XF's Avatar
Default Fusible link on battery +ve
I seem to have clumsily broken off the small wire on the battery positive terminal when re-installing the battery after charging. I believe the gizmo where the small wire is attached to the +ve terminal is a fusible link. Can anyone tell me what amp rating this link is? I'll get some fusible wire and solder it in.
Old Sep 15, 2024 | 05:42 AM
POD XF's Avatar
Stand down on this; I initially thought that there was a very short length of fusible wire contained in the heat shrink at the end of the wire- it turns out that there is about 4" of fusible wire and the heat shrink is at the end of it where it joins to a short piece of normal wire which is crimped to the terminal. I stripped this back a little and crimped another terminal on. All back together and no charge warning on the dash.
Still waiting for my new multimeter to arrive so I can investigate the parasitic drain.
okmores
Jan 30, 2022 05:37 PM
So Charlie
Feb 10, 2020 03:20 PM
rlembach
XF (X260)
Jun 26, 2017 09:30 AM
Alex O'Brien
XK120 XK140 XK150
Sep 25, 2016 09:49 PM
Jason Souhrada
Jan 13, 2016 04:24 PM
