Gear shift module - no power- car starts but cant put it in drive.
Old Jan 15, 2020 | 09:38 AM
clubairth1's Avatar
Community Influencer
Is it a new module (never has been programmed before?) or a used module?
How much do you know about SDD?
Have you ever programmed a module before?
Tell us EXACTLY what setup you have running SDD now.
Old Jan 15, 2020 | 10:16 AM
autocarJag's Avatar
I fix it.
I put a new module , program it, done
Old Jan 21, 2020 | 11:47 AM
waynehavens's Avatar
How did you program it?
Old Mar 1, 2020 | 04:17 PM
Claudio Pozzi's Avatar
Default Same issue
Originally Posted by Kodwo Cohen
yes, that info is actually in the owners manual. ive had to release the park before...
Right now I have completely gutted my Jag, theres nothing but wires inside..lol. figured i would finish customizing it while i have it all taken apart for this issue...
Did you figure out what the problem was? I’m having the same issue with my 2012 Jaguar XF Supercharged V8
Old Apr 27, 2020 | 08:42 PM
car5car's Avatar
I bought a dead 13 XF with 3 gear shift modules.
I guess, previous owner kept buying used ones until he gave up.
Old Nov 23, 2020 | 09:12 AM
raggeew's Avatar
Hello. I have the same problem. Intermittant faulty gearbox. Is there any solution?
Old Jan 9, 2021 | 01:08 PM
Brake buster's Avatar
i have just got through the exact same issue, sadly no contact with OP with his issue
I FIXED IT !!
i found that my 2015 X250 Sportbrake had a battery supply issue to the GSM ( not the ignition or wake up signal or other wiring )
as it had no power, the ECU and all related equipment throws a fault of no communication etc etc, ignore it, the module supply is the issue ,
this is pin 20 on the C33-C connector ( C33-C/20 ) , yellow and red trace, no power with ignition switched on ( as others, engine runs, handbrake works, but no GSM functions ) and sometimes intermittent ( this connector is behind the console left side trim in the middle, and can easily be got to )
the cable comes from fuse 26 , a 10a in the engine bay fuse box, and is a direct feed to the GSM , but does go thought C13-C/16 and C33-C/20 connectors , and also has a splice before the C13-C connector to supply the TCM module,
i bypassed this cable completely by holding a wire in the fuse holder in the engine bay with the inserted fuse, and then using the wire into the C33-C/20 position with the yellow and red wire,
hey presto, worked first time, and every time
this means the wire is broken somewhere !!
try this and if it works , its your issue ( at your own list i might add )
very little if any info about this on the Jag forums at all.......
good luck
BB
Old Jan 11, 2021 | 06:03 PM
  #28
clubairth1's Avatar
Thanks for posting back as we never did hear if the OP got his fixed or not.
Old Jan 13, 2021 | 09:32 AM
final update, permanent fix put in place by bypassing the broken wire,
it works first time every time now ,
BB
Old Aug 13, 2021 | 02:45 PM
  #30
Mehul Bhatt's Avatar
Default Jaguar XF 2008 2.7 D, Gear shifter issue.
YEah, i saw some of those, none of them seemed to fit the scenario to me. also I put my VIN in the recall database and only one popped up (which is unrelated but i will be having looked at as soon as im done with this). However, I have been doing more troubleshooting...
when i was going back through my continuity testing, i noticed a random tone where it shouldn't have been and realized the connector C33-C was faulty and shorting out.
i replaced the connector, but when i plug into the GSM i still get the same readings. (which leads me back to the GSM) unless something beyond the GSM is causing a short and blowing the GSM circuit. which i would hope wouldnt happen.
to confirm my theories for myself, by taking the GSM apart myself and found corrosion and damage on the circuit board.
i have obtained another (used) Replacement GSM but my current concern is if something else is shorting it out after the GSM that may have caused the same issue in the first replacement GSM..
another theory is that the second may have been shorted out the same way the first one could have been in by the damaged C33-C connector. now that its been rebuilt, im wondering if that could have cleared the issue...
so before i just go plug this one in, im going to do a bit more research first to make sure im not just blowing my money up soon as i plug it in...lol
Did you find out some solutions,?
I’m having same issues in my Jaguar XF 2.7 2008. This issues started in February this year. I can see any power in gear shifter module, however I can start the car and use the parking brake.
I bought another gear shifter online and after that it’s worked perfectly fine until yesterday. Same issues again ,! I’m really surprised that how come same issues again in new part.
look like maybe faulty electrical issues or I read in some post that might be water is running inside wiring loom. Please help me if you sorted out your issues. Looking forward to hearing from you.
Connector
No power in module.
Gearbox Fault
Park Brake
Special mode not available
Old May 11, 2022 | 02:04 PM
  #31
Starter's Avatar
Default I have the same problem
I FIXED IT !!
good luck
BB
Hi,
I know you posted this a while ago, but was hoping you may be able to help as it seems you have more knowledge about electricals and was able to fix your problem. Having stumbled on your post, i see you has the exact same problem i currently have.
I have been able to get the gear seletor out but the wiring configuration seems different to yours and was hoping you may be able to point me in the right direction. I have attached a picture of my socket and its wiring. You mentioned that it was pin 20 on your connection but my pin 20 wire is not yellow with the red trace, on my connection yellow with the red trace is pin 1. The wire in my connection for pin 20 is green with orange trace.
I appreciate that this is at my own risk but thought i would ask.
Many thanks
Old May 31, 2024 | 02:18 PM
  #32
Shakp's Avatar
Connector
No power in module.
Gearbox Fault
Park Brake
hi PLEASE TELL ME YOUVE SORTED THIS ISSUE OUT
Old Jun 10, 2024 | 08:24 AM
  #33
AndreevBG's Avatar
Позицията не е на този конектор. Продължете надолу по кабелния сноп и намерете следващия конектор, както човекът е показал на снимката си. Успех
Old Jun 10, 2024 | 03:41 PM
  #34
Shakp's Avatar
NO ONE BOTHERED HELPING BUT FINALLY FIXED, if anyone has this issue after changing gearselector you have to have exact part number from dealership!!!!
Gophat
Sep 5, 2017 04:46 PM
kmschaer
Mar 30, 2015 07:16 AM
wotcham8
Nov 9, 2013 07:05 PM
myjaghasspark
Dec 22, 2011 01:42 PM
Disco stu55
Aug 15, 2010 10:34 AM
