Gearbox fault
Old Nov 11, 2021 | 04:23 AM
jegan raj's Avatar
Default Gearbox fault
My jag 2011 xf reverse doesn't moves sometimes.
R symbol blinks but no moves.after try D mode for a bit forward then R means it will works or switching off the engine then restart also working fine otherwise I feel better in fwd gears.
Also I'm feeling like auto gear shift taking time to shift to next gear and pick-up issue.
Can anyone facing the same problem means pls let me know with the solution.thank u so much in advance
Old Nov 11, 2021 | 07:34 AM
JagV8's Avatar
Maybe first check the 2 bolts holding the shift cable onto the trans are present & not loose.
Old Nov 11, 2021 | 11:54 AM
Six Rotors's Avatar
Time has moved on since your S-Type. The 2011 XF is all electronic from the JaguarDrive selector on the centre console -no Bowden cable to the transmission.
Old Nov 11, 2021 | 07:41 PM
BritCars's Avatar
Can be a battery issue. Sometimes the shifter itself is failing. Did you pull any codes from the car?
hockers
Jun 21, 2019 11:10 AM
AC0FC
Mar 30, 2017 04:58 PM
Christine51
Feb 1, 2015 12:01 PM
fjroze
Jan 31, 2014 10:11 AM
nigelharley
Jan 5, 2011 10:39 PM
