Has anyone tried a LITHIUM battery in the Jag?
Old Dec 11, 2020 | 01:37 PM
Sterling Smith's Avatar
Default Has anyone tried a LITHIUM battery in the Jag?
I see a lot of battery related issues in the Jag forums, I am curious if anyone has tried switching to a Lithium battery? They hold their charge longer, higher CCA, put out higher amps for longer and most importantly charge faster. From what I have read the AGM batteries don't charge fast enough for our Jag's charging system causing chronic low voltage and that creates more issues. Lead acid go out often and can't go below 50% without damaging them and have more problems in general, it seems a good hi-amp alternator and Lithium battery would solve all of our issues with low voltage for good and they are lighter to boot. I changed my battery once and almost blew an artery trying to put that thing in a tiny space in the trunk. It went out a year later, no fault of the car I had it on a trickle charger that was highly rated. They have longer warranties and rated to last 3X longer than lead acid. They are not that much more expensive either anymore on Amazon.
Amazon Amazon
Old Dec 11, 2020 | 03:46 PM
OzXFR's Avatar
Check out Unhingd on the F-Type forum, he put a lithium battery in his F-Type years ago and it has been trouble free since.
Highhorse
Feb 11, 2025 05:13 PM
richardcox52
Dec 15, 2016 07:02 AM
lsbrodsky
Jun 18, 2016 09:09 PM
TXJagR
Mar 12, 2016 11:12 AM
oyster
Feb 27, 2014 02:51 PM
