Help
Old May 22, 2022 | 09:04 PM
kthoma's Avatar
Default Help
Is there a way I can restore this headlight and keep it from peeling?
Old May 23, 2022 | 02:41 AM
I've moved your question from X260 to X250 forum. This is the place to post questions about your model.
Old May 23, 2022 | 10:50 AM
2018XF25T's Avatar
It happens to a lot of cars on hot climates that is parked directly from the sun. Here in Texas, it is too common. The UV clear coat protection peels off for several years on cars parked without a garage. If this happens to me I will lightly sand with fine grit and buff to take the old clear coat out and do a re-coat. The other lens needs to be done as well to match the two together. Good luck
glm2006italy
Aug 16, 2022 09:44 AM
scottpeterd
Nov 4, 2021 10:23 AM
pcolapacker
Sep 27, 2021 12:52 AM
Boeingtravel95
Aug 27, 2013 08:09 AM
offroadking208
Nov 28, 2012 06:06 AM
