Help with audio system upgrade
Old Sep 3, 2016 | 08:41 AM
sparkie79's Avatar
Default Help with audio system upgrade
I'm trying to upgrade a Midline Sound system on my 2012 Jag XF mounting a
Bower and Wilkins set of speaker.
I mounted the new amplifier (BJ32-19C164-BF) in place of the old one, changed CCF configuration with Audio system "Midline" to "Premium" option, subwoofer and central speaker option enabled.
Now i see new options into the nav menu (dolby, subwoofer) but not sound come out from speaker.
I update module software using sdd procedure "configure new amplifier module" and "configure new audio control module" without result. No audio.
A DTC appeared with code U3000-55 "incorrect configuration".
Anyone has some ideas?
Old Sep 3, 2016 | 09:20 AM
08292's Avatar
You need to update software for IAM2.1 head unit.
What version of SDD and cable you use?
Old Sep 3, 2016 | 12:33 PM
sparkie79's Avatar
I use sdd 1.46.006 with a jlr mongoose pro cable (clone)
Old Sep 3, 2016 | 12:36 PM
08292's Avatar
When you programming amp in the end of process the error codes clearing or you need to disconnect the battery for DTC codes cleared?
Old Sep 3, 2016 | 12:46 PM
sparkie79's Avatar
I have to disconnect battery.
When i started the procedure, sdd asked me te type of hardware among EW32 A, EW32 B or Original AAM. I choosed AAM...
Old Sep 3, 2016 | 12:49 PM
08292's Avatar
When you need to find VCM or genuine MongoosePRO, because with this clone you can't end programming procedure correctly.
Old Sep 3, 2016 | 12:54 PM
sparkie79's Avatar
The programming process howewer ask me to clear codes at the end of the procedure. the code of the software downloaded start with cx23. If i do a speed dynamic volume calibration i can hear sound coming out from speakers
Old Sep 3, 2016 | 01:04 PM
08292's Avatar
Try to update SW for head unit firstly.
Old Sep 3, 2016 | 01:10 PM
sparkie79's Avatar
mmm done. I updated head unit via a procedure that required to copy files on usb key several time, after i retried to update amplifier... maibe the unit is not compatible with my head unit? I have an extra connector on new amplifier. Is gray and look like an usb socket
Old Sep 3, 2016 | 02:25 PM
08292's Avatar
This socket for Whitewire connection which using for headphones.
Old Sep 5, 2016 | 01:29 AM
sparkie79's Avatar
yesterday I've investigated the problem a little. Analyzing sdd session logs seems that when i start procedure to configure a new AAM unit, ssd identify the new unit but when it compare the unit code with the "as built" data of my car, decides to upload software and calibration of the old unit.
Today i will try to load software manually using engineering mode.
Old Sep 5, 2016 | 01:51 AM
08292's Avatar
If you using 146.06 asking you don't use softwaremanager.htm!!! The best way start new SDD session and enter engineering mode via "golden key" pass
Old Sep 5, 2016 | 02:02 AM
sparkie79's Avatar
Ok, when i enter the key nothing happen. I will have some extra menu enabled?
Old Sep 5, 2016 | 04:00 AM
08292's Avatar
You need engineering code for some tricks with SW, but you can't reprogramming correctly modules with cloned MongoosePRO.
Old Sep 5, 2016 | 04:42 AM
sparkie79's Avatar
I have the engineering code.
In engineering mode i can decide what software upload on modules?
With my mongoosePro i managed to load the bad software on AAM module, i think i can load the correct one in the same manner.
Old Sep 5, 2016 | 05:22 AM
08292's Avatar
Firstly you need to find genuine MongoosePRO or VCM, because most of cloned ones can't correctly upload SW to modules, so now with your cloned cable you have a very high possibility to damage, or even kill module.
Old Sep 5, 2016 | 05:38 AM
sparkie79's Avatar
Well, i understanded the concept. I will buy a genuine cable soon.
When i have the cable, with the engineering code i can decide myself what software load on modules?
Old Sep 5, 2016 | 04:36 PM
sparkie79's Avatar
Problem solved!
Forced sdd to detect and download software for the new amplifier with my cloned tool. It was enough to modify the 'as built' file in sdd.
Old Mar 6, 2018 | 07:47 PM
harryf's Avatar
Problem solved!
Was there any specific thing you needed to do to detect the new amplifier. I've always had SDD just try to install the old amp software, so I gave up reprogramming my amp.
Old Sep 1, 2019 | 09:49 AM
enzofl2's Avatar
Exclamation
Problem solved!
Hello sparkie79. At least explain what you did. Forums are for sharing. I also have the same problem on FL2My13. How did you edit 'as built' file in sdd? Which version of SDD do you use? Which SDD procedure did you use? You could only help me if you're a little more precise, thanks.
