Help On parts
Old Jul 5, 2018 | 06:21 PM
ariba's Avatar
Default Help On parts
Hello
I am buying a few engine plastic hoses part & other engine related for my 2011 XFR 75k Miles. Before my budget was about $1200 to spend but now I needed some of my money go to my classic C3 Corvette Restomod + travel expenses. So I cant go more than $700
I Just bought water pump, valve cover gasket MAHLE VS50675, oil pump gasket, front and rear brake rotors & pads, K&N Air filter, Maina Gallery Air tube, Front & rear tires, trans oil filter.
There is a coolant smell but not seeing leak.
1. I want buy the important parts
2. If some one fined a part don't fit to my 2011 XFR pleas let me know.
I am buying from checkeredflag.com
Old Jul 7, 2018 | 07:51 PM
ariba's Avatar
Waw No any answer
Old Jul 8, 2018 | 01:01 AM
santer's Avatar
Why are you replacing all those?
Maybe helpful to know what caused them all to need replacing
Old Jul 8, 2018 | 05:39 AM
Bart Lenferink's Avatar
Hello Ariba,
If money is the issue, my approach would be:
- Have a spare car and take your time to go through the process of replacing
- Visually inspect and possibly test each part when disassembling and replace only those you suspect
- Allways replace O-rings and gaskets
- I also find it difficult to be sure to have the right parts, therefore I normally ask for a quotation according to the VIN number of the car (works great with www.britishparts.co.uk)
Good luck!
Regards,
Bart
Old Jul 9, 2018 | 05:06 AM
ariba's Avatar
Thanks Santer & Bart . I know That most Jags need to change most of the hoses. I had an experience with my 2004 70k miles XJR. I do have a spare car but I don't want to replace 1 hose and find the other is more important. or find the other fail after a month. My brother smell coolant but no leaks maybe the water pump or the rear hose.
Old Jul 11, 2018 | 01:49 AM
santer's Avatar
May be the expansion tank and if it is spraying on to a hot part of the engine it could be evaporating so hard to see?
If it were me, I would replace a hose and if it was a lot of work to get to it, replace any others near to it
Old Jul 11, 2018 | 04:26 AM
Throwing parts at a Jaguar is a very expensive way to troubleshoot. Coolant smell - replace everything would NOT be my approach.
Are you losing coolant and, if so, is it a significant loss? If it is a significant loss, a pressure test kit will help identify the source. If it is minimal, a regular cause on several Jaguar models is the Expansion Tank. Any pinholing or seam faults here are only noticeable with a hot engine.
Investigate first - then spend as required.
Zorasmiles
Sep 5, 2014 05:40 PM
etaent
Aug 22, 2014 07:55 AM
edselsouth1
Dec 1, 2011 08:05 PM
westveld
Jul 2, 2008 08:46 AM
