How to detect vacuum leaks on 5.0 SC
Old Jul 21, 2022 | 01:27 AM
Erobles396010's Avatar
Default How to detect vacuum leaks on 5.0 SC
Hello i need help on this i have a 2012 xfr and im hearing a loud hissing sound and a whine coming from the engine sound like the passenger side. I replace the tube that runs from the throttle body to the passenger side of the valve cover i also replaced both of the pcv valves and im still get the loud hissing sound the car has 94k miles. I also took it to a shop they did a smoke test and they said it was the hose i replaced but its not its a hose i got from jaguar. I also move it but it does not change the sound of the vacumm leak im gonna try to add a video so you guys can hear it its a link to youtube also i had a code p0171 lean on bank 1 but after i replaced the pcvs it has not come back
Old Jul 21, 2022 | 03:43 PM
pab's Avatar
pab
Well ...
in the past I used to use a can of starter fluid to locate leaks (do they even sell that stuff now a-days?).
With the engine idling I would spray the fluid towards where I though the leak might be.
If the RPM of the engine didn't change, I hadn't found the spot.
If the engine raced, I had it.
You'd think that old shade-tree trick might still work, even with an intake system as complex as a supercharged Jaguar.
Good luck, and let us know what you do.
Current Hers: '13 Lexus ES350
Current Mine: '15 Jaguar XF (X250) Portfolio AWD
Jaguar - making mechanics out of customers since 1935
Old Jan 18, 2023 | 06:40 AM
shc230247's Avatar
A small hose attached to the rear of the upper left intake manifold was missing. Part number is XR853367,
pipe INLET MANIFOLD upper left. This fits at the rear of the upper manifold. The hose on the left (looking from the
rear) fits onto the FUEL PRESSURE SENSOR - however - the hose on the right has (apparently) nothing to
attach to? Is there a vacuum hose missing completely ?
Any assistance would be gratefully received.
Many thanks
Stuart
Old Jan 19, 2023 | 02:48 PM
clubairth1's Avatar
Community Influencer
That does not look like the SC 5.0L engine?
Does the 5.0L have IMT?
Old Jan 20, 2023 | 06:57 AM
shc230247's Avatar
It is a V6 3.0 litre Petrol (gasoline) engine. Similar to the old V6 Ford 3.0 litres many of the parts are
the same.
Old Jan 24, 2023 | 03:05 PM
Reaxions's Avatar
The OP said he had a 2012 XFR - what the hell hell are you talking about? Those pictures don't look like anything I've seen around the 5.0 SC engine, and I've been around it for a while.
Old Sep 26, 2024 | 06:39 PM
gretle_2.0's Avatar
Originally Posted by Erobles396010
Hello i need help on this i have a 2012 xfr and im hearing a loud hissing sound and a whine coming from the engine sound like the passenger side. I replace the tube that runs from the throttle body to the passenger side of the valve cover i also replaced both of the pcv valves and im still get the loud hissing sound the car has 94k miles. I also took it to a shop they did a smoke test and they said it was the hose i replaced but its not its a hose i got from jaguar. I also move it but it does not change the sound of the vacumm leak im gonna try to add a video so you guys can hear it its a link to youtube also i had a code p0171 lean on bank 1 but after i replaced the pcvs it has not come back https://youtube.com/shorts/E8zSuZuSX60?feature=share
did you ever find out what it was? I’m getting a hissing sound from same area too but no code
justinw
Aug 10, 2021 09:13 PM
mlrtime99
Jun 26, 2021 04:00 AM
lpf4
May 26, 2021 04:25 PM
CRS 123
Apr 17, 2017 12:11 PM
ericjansen
Jun 29, 2014 04:45 AM
