View Poll Results: Why is my Jaguar xf 2012 swinging and not starting
What is the problem
100.00%
Is it the fuel pump lume
100.00%
Why is it just swinging
100.00%
How can I go forward
100.00%
Is it anything else
100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
I think my mechanic is beating around the bush
Old Jan 18, 2021 | 04:11 AM
Ab1's Avatar
Ab1
Default I think my mechanic is beating around the bush
Hi please if anyone could assist me. So about a 3months ago my 2012 Jaguar xf 3.0 diesel was just cutting of as I was driving. And at one stage it just wasn't starting. So the mechanic said the Fuel filter needed to be changed, changed that....same problem. Then he did some diagnostics...got it started I dropped him home, next day the same story. Now he says its the lume connecting the fuel pump. He came through yesterday started over revving the car for some reason, opened the fuel pump put it back...kept fiddling with the lume. The exact same thing is happening. It's only swinging, and if it does start it switches off right away. And I keep paying him everytime he comes to get it started! I have a feeling if we change he lume he's going to say its something else or is it just me. Please assist me so I'm sure not to call him again if he's just using me to make more money.
Old Jan 18, 2021 | 04:52 AM
Reead Boodhoo's Avatar
Reason why he thinks its the loom?
is there enough gas in the tank?
Old Jan 18, 2021 | 05:18 AM
Welcome to the forums Ab1,
Please do NOT start a Poll as a first post. It is NEVER the best way to get help and advice.
You mechanic can go on guessing the possible cause(s) at your time, expense and increasing frustration OR he can run a Jaguar diagnostic session looking for relevant error codes to assist in more systematic troubleshooting.
Old Jan 18, 2021 | 07:23 AM
John Williams's Avatar
There is a TSB about a poor connection to the tank sendor/pump. I thnk there is a small repair loom?
Remove the rear seat & check the multiplug for loose connection!
Shibajack
Jan 12, 2015 10:06 AM
heuster
Feb 22, 2014 06:27 AM
Otokunor
Sep 30, 2013 03:13 AM
OliverB
Jul 16, 2013 04:02 AM
juans_jag
Oct 20, 2008 04:29 PM
