IAT bank 1 sensor 2 location
Old May 19, 2023 | 11:04 AM
Loganllopes's Avatar
Default IAT bank 1 sensor 2 location
Intake air temp sensor bank one sensor two is reading -40. But I can’t find the location of the sensor.
Old May 19, 2023 | 04:38 PM
kansanbrit's Avatar
Pretty sure there aren't individual intake air temp sensors. In fact pretty sure there aren't any intake air sensors at all on the NA engine.
Old May 19, 2023 | 04:51 PM
Bigv's Avatar
Is it not built into one of the maf sensors?
Old May 20, 2023 | 11:11 AM
JagV8's Avatar
What tool says exactly that?
As well as the IAT near/in the MAF there's one to monitor the SC charge temp, but I know it as IAT2. Maybe the same one?
What code are you seeing?
BTW would help to add your car details...
Old May 20, 2023 | 02:59 PM
2015 XF 2.0 turbo
after I replaced both fuel pumps, I tried to reset adaptives but scanner said iat was -40, and wouldn’t allow me to. Checked data and IAT 1 (in MAF) was reading properly. 68, and -40 when unplugged. Car came in no start. Low fuel pressure and low volume . Did primary pump first car ran , but not as expected. Scanner data showed 400 psi at idle. Then replaced high pressure pump. Now I get 420 at idle.
Old May 21, 2023 | 09:59 AM
kansanbrit's Avatar
Yes, apparently they are.
machavaram
Nov 24, 2019 12:56 PM
Cee Jay
Sep 20, 2019 01:56 AM
Clamdigger
Feb 16, 2018 03:40 PM
awil
Jun 17, 2014 10:46 PM
penguin
Mar 30, 2012 04:06 PM
