Incomplete phonebook
Old Apr 23, 2012 | 10:04 PM
Escolar's Avatar
Default Incomplete phonebook
I've got a Samsung Droid Charge. According to the Bluetooth Connectivity Centre, everything should work except for the call lists for Android 2.2.1. Actually, with phone firmware 2.3.6, call lists do work.
Trouble is the phonebook. Several of my most important phone entries don't show up at all, and there are large gaps in the data. For example my son's name is missing but there are alphabetic entries before and after his name, so I don't think it's a capacity thing. I do have probably 1000 or more entries, though.
Does anyone have a clue about this?
Old May 22, 2012 | 05:13 PM
4newjagownr's Avatar
Noticed this also when I joined two iphones with iOS 5.x.x to the 2010 XF Premium, that the phone books were missing entries. Must be a firmware issue with the headunit. Is there a update?
Old May 22, 2012 | 06:06 PM
jagular's Avatar
Somebody suggested the car's hard drive may not have enough space for large address books.
Old May 22, 2012 | 06:50 PM
aahmichael's Avatar
I have no doubt that your phonebook is too big for the car's memory. For example, the unit in the XK can only hold 750 names/numbers.
Old May 23, 2012 | 06:37 AM
ivanov's Avatar
Something worth checking: what names (or fields attached to names) have apostrophes? In my workplace, any address entry with an apostrophe forces the rest of the address book to be dropped from our syncing server.
I'd also check for any rogue characters in any of the address book fields, and as a test, remove (temporarily) any suspicious entries to see if this fixes the problem.
gmcgann
May 13, 2013 12:07 PM
wedgewa
Mar 12, 2012 02:38 PM
DReffects
Mar 11, 2012 01:41 PM
manicguitarist
Nov 28, 2011 04:15 PM
exrub
Aug 24, 2010 09:02 AM
