Intermittent P0106 error code?
Old Sep 29, 2020 | 10:33 AM
khsjsilver's Avatar
Default Intermittent P0106 error code?
A couple of months ago, my XF had a check engine light with a P0106 error. It lasted a couple of days and then the check engine light went off. I called the dealer and they said that as long as the light went off, i'm ok. Not to worry. This morning, the check engine light came on again. Same error.
Is is ok to drive around with this error? Is it something that could damage the car if I drive with it? Should I clear the error code and see if it comes back on again?
Help is appreciated.
Ken
Old Sep 29, 2020 | 10:36 AM
JagV8's Avatar
It likely means the car can't get fuelling right but to my mind more importantly right now would be why is it happening.
If you're unlucky it could be water in something really important like the PCM - but lucky if so in that you've been alerted via a code!
I don't know where BARO sensor is in your car but mine is inside the PCM and water would be a scary suspect...
Old Sep 29, 2020 | 10:54 AM
Maddshadez's Avatar
I had the same issue, it was a dirty throttle body and MAP sensor. Cleaned them up and the code never returned.
Old Sep 29, 2020 | 06:07 PM
Jag#4's Avatar
Check the intake tube from the air boxes to the throttle body. It's plastic and prone to cracks.
Mine fell apart when I pulled it off for examination.
Old Oct 3, 2020 | 08:07 AM
khsjsilver's Avatar
One day later, the check engine light disappeared. 3 days later the light has not come back on. I guess that's a good thing, but a little exasperating. The dealer told me, again, not to bring it in if the check engine light is not on. I guess I'll wait to see if it comes on again.
Ken
nickdabs
Feb 21, 2020 05:59 AM
rogerpaulsen
Apr 22, 2019 08:19 PM
jelu02
Jun 8, 2018 08:09 AM
tommy8850
May 25, 2012 10:20 AM
brgjag
Aug 13, 2008 01:34 PM
