Jaguar XF 2012 2.2 DT click sound and no starting
Old Nov 27, 2017 | 01:57 AM
Ronald Molosiwa's Avatar
Default Jaguar XF 2012 2.2 DT click sound and no starting
Thank you so much for the reply, I am going to ask the Mechanic to take out the starter and send it for rebuild. The other information is that I put the Delphi OBD reader : the fault code states Engine Control module voltatage supply ( first entry). Should I still take out the starter for rebuild or the ECU needs replacement or checking.
