Jaguar XF 2012 Sport Brake BCM Fault (Solid State Protection)
Old Jul 2, 2024 | 05:35 PM
MikeyB93's Avatar
Default Jaguar XF 2012 Sport Brake BCM Fault (Solid State Protection)
Hi All I've got a very strange problem with my Jaguar XF Sportbrake, in Both Front and Rear BCM i have codes for solid state protection, in the front bcm i have 31 faults codes for all elctrical outputs as i believe the solid state protection code disables all outputs.now i've tried to have a second hand BCM cloned as when plugged in before cloning all trouble codes were gone apart from ignition authorization and vehicle identifier codes, when the module has been cloned all the codes are now back and wont clear, has anyone seen this before or know of a fix ?
Old Jul 7, 2024 | 02:49 PM
MikeyB93's Avatar
FIXED !!! So the way i fixed this was getting the BCM Flashed with a 'VIRGINIALISED' File, after this had been done i programmed it back to the car with SDD and everything came back too life
Old Jul 12, 2024 | 01:33 AM
2010XFPushBrakeHarderToStart's Avatar
How exactly did you do that?
Old Jul 12, 2024 | 02:56 AM
MikeyB93's Avatar
Disconnect the battery and remove the front BCM then my friend who codes keys has software to read the EEPROM on the BCM, he then flashed it with a “Virginialised” File (removing all information so it’s as new) refit to the XF and code the module as new with SDD Jaguar Software
Old Jul 12, 2024 | 02:31 PM
Thanks for letting me know!
Old Jul 13, 2024 | 07:22 PM
FerdinandG's Avatar
are you in Florida by any chance?
I bought a 2015 XFR with this BCM fault.
Gigisnails
53
Jul 23, 2023 02:50 PM
pk4144
Jul 11, 2023 07:33 PM
dennis black
Mar 12, 2023 10:20 PM
Reece6776
Mar 3, 2023 12:49 PM
Tony_Likes_Going_Fast_XJ8
Dec 3, 2022 04:12 PM
