Jaguar XF 2013 'battery not charging' warning
Old Aug 26, 2018 | 07:12 AM
sulthan_amk's Avatar
Default Jaguar XF 2013 'battery not charging' warning
I've a message pope up in the display, 'battery not charging' and all of a sudden the steering got locked. What could be the possible reason? i replaced my old battery with a new battery a month before.
Old Aug 26, 2018 | 10:08 PM
lotusespritse's Avatar
Uh, the thing that charges the battery: the alternator
You were probably slow to change out a bad battery, and the bad battery put a strain on the alternator, and now you get to replace that too.
Old Mar 20, 2020 | 03:14 AM
Emad Al Skoti's Avatar
Default Battery not charging
Not necessarily, you can check the altenator voltage while car is on/off. Use voltage meter
Old Dec 12, 2022 | 10:09 PM
Fkhatib's Avatar
Hello Sultan, I had the same problem yesterday. Did you find the reason for it?
ClassicCarRepair
XF (X260)
Jan 9, 2025 12:19 AM
jagxkrtoofast
Dec 9, 2022 12:56 PM
DannyRobertHoward
Apr 5, 2018 03:15 PM
LoveHerTopless
Feb 8, 2018 11:47 PM
Qgregg
May 2, 2012 07:42 PM
