Jaguar xf abs/dsc warning lights problem
Old Oct 24, 2014 | 07:07 PM
Venomous11's Avatar
Default Jaguar xf abs/dsc warning lights problem
Having a problem with abs and dsc warning lights. It's on a 2009 Jaguar xf. Had a new differential installed because of a boot leak. Also had bearings in the rear end changed. Now the abs and dsc won't work. Jaguar dealer said the bearings might have been installed backwards. So I just had mechanic install new ones again with no luck. Please help me with this issue.
Old Jun 25, 2019 | 10:53 AM
wesmc's Avatar
I have an 09 XF with ABS/DSC lights on. Looking at the hub it looks like the sensor is located above the axle, not the bearing. Also, there is no obvious reluctor on the axle. I see the sensor part # changed between '09 and '10. Anyone know for certain where the reluctor is in '09
BrentGardner
29
Dec 16, 2024 12:13 AM
tberry6686
Sep 20, 2015 03:22 PM
gene1
Sep 3, 2015 08:04 PM
tberg
Aug 31, 2015 04:33 PM
gene1
Aug 27, 2015 08:56 PM
