Jaguar XF display screen flickering / flashing
Old Feb 3, 2016 | 11:16 PM
BritCars's Avatar
How does it get so full of water? Are all the other modules around it wet too?
Old Feb 4, 2016 | 06:11 AM
STRIVEMIAMI's Avatar
I am not sure, i just bought the car. But after a heavy rain, i notice the carpets were soaked. Digging further on the net, i see its a common problem with owners.
Old Feb 4, 2016 | 08:58 AM
tbird6's Avatar
If your carpets are getting wet are you sure the Moon Roof is not leaking? The drains are a known source of water leaks.
Old Mar 9, 2016 | 11:54 AM
jaguarxfv8's Avatar
Default get wet
Yes the other module are wet but they are made of steel so it just get rusty, but to be sure I secure the plug with duck tape lol.
just have to always put some rubbermat on the floor, bigger one for winter and thin one for summer.
Old Apr 11, 2016 | 01:55 PM
stillka's Avatar
Hello,
on my XF SV8 (2009), modules under driver seat was missing (used car).
So no Bluetooth or USB audio (I have premium audio Bowers & Wilkins).
I have found used Bluetooth Phone Control Module 7G9N-10D893-AF and installed it,
Bluetooth is working fine now (great!), last think to fix is USB/iPhone audio, the cable is rusted and need to be replaced (Ipod to AUU Module Wiring Harness Loom C2Z4708). What else I need to fix USB/Ipod audio? Only new C2Z4708 cable?
I have console USB/AUX/iPod socked in place.
Old Apr 18, 2016 | 06:54 PM
jaguarxfv8's Avatar
Originally Posted by stillka
Hello,
Do you mean your usb/aux/ipod doesn't work or the box module under the seat was just rusted? Because mine was too but it's in metal so it doesn't really Matter water dont get in. For My part just changed My Bluetooth module and every thing was fine again !
Old Apr 18, 2016 | 11:43 PM
stillka's Avatar
Hi, this module in metal box is missing + rusted ipad cable (connector on module side). What is the Jag code of this module? I have there only bluetooth module (plastic case)...
Old Apr 25, 2016 | 12:45 PM
  #28
jaguarxfv8's Avatar
Default audio portable module
The module you're talking about is the AUDIO PORTABLE MODULE
Here are the picture of the module with code on it and cable for iPhone/ipad connection
Attached Thumbnails Jaguar XF display screen flickering / flashing-audio-portable-module.jpg   Jaguar XF display screen flickering / flashing-jaguar-connector-1.jpg
Old Jul 28, 2016 | 03:28 AM
chris009's Avatar
Hi All,
I'm new to the forum and I'm sorry for bringing this up again; I have the same fault in a 2009 xf. I've been told it is the ipod module, is this the same as the Bluetooth module? Also, how easy is it to refit the carpets etc? how long a job is it?
thanks in advance,
Chris.
Old Jul 31, 2016 | 12:40 AM
  #30
jaguarxfv8's Avatar
Yes it's the Bluetooth module, all you have to do is unbolt the driver seat and take off just a little bit of the mat floor and work your way Under it but if you want space to work a suggest you take it all off. the hardest part to put back is Under the jaguar panel but I think you can take them off too.
Old Jul 31, 2016 | 03:09 AM
  #31
chris009's Avatar
Thanks, I managed to get the module out, but the grey connector is stuck. I'll need a new one, does anyone know what the part is please?
Old Aug 31, 2016 | 03:38 AM
  #32
stillka's Avatar
Hi, I bought the APM from the ebay and fixed rusted MP3 cable, but there is another cable which need to be plugged to the module and I cant find it in car, this black square connector, any idea what cable I need?
Old May 7, 2017 | 05:16 PM
  #33
Rique's Avatar
Default Second metal box
I'm reviving this thread in hope someone can help. I have had the same flickering screen due to flooding of the driver side floor pan. I have purchased a used Bluetooth module but it did not work.
My question is if the bottom box needs to be changed as well. They are interconnected and it seems work together. The board on my blue tooth module looks OK but is was wet so I guess its history. The bottom metal box however looks in dire condition.
Thanks for any input.
Attached Thumbnails Jaguar XF display screen flickering / flashing-jagboard1.jpg   Jaguar XF display screen flickering / flashing-jagboard2.jpg   Jaguar XF display screen flickering / flashing-jagboard3.jpg   Jaguar XF display screen flickering / flashing-jagboard4.jpg
Old May 8, 2017 | 10:15 AM
  #34
clubairth1's Avatar
Community Influencer
Does that module need reprogramming to your car?
Many modules now a days are not plug and play.
Old May 8, 2017 | 10:42 AM
  #35
Rique's Avatar
I agree but from others on the thread I understand this is PLUG N PLAY
Old May 8, 2017 | 11:33 AM
  #36
jaguarxfv8's Avatar
Default No
it's plug and play
Old May 8, 2017 | 11:37 AM
  #37
jaguarxfv8's Avatar
Default Change both
The fist time I only changed the bluethoot module and it blew and couple mounth late .. I changed both box and no problem since ... I sugest you change both but it's expensive so check on ebay first ! And check all other component under and around the flooded zone because it might have been touched too! And when you reinstall the module I sugest you let some space in between the box module and the floor otherwise water will always touch it !
Old May 8, 2017 | 12:08 PM
  #38
Rique's Avatar
I got a used Bluetooth box and changed it and no results. I will get the second box as well and try with both.
Old Jul 10, 2017 | 10:42 AM
  #39
Bklyn1971's Avatar
I had the same issue with mine last month. Went out and bought a Bluetooth module after reading this post and still didn't fix the issue. I finally broke down and took it to a Jaguar dealer. Wound up being the 30amp radio fuse in the trunk. They said all the modules checked out fine. I even had them put the original BT module back in the car. If anyone is looking to buy one of these let me know. I have an extra one.
Old Jul 10, 2017 | 11:02 AM
  #40
Rique's Avatar
Thanks for the update. What year is your car? Where exactly is the fuse box in the trunk?
