Jaguar XFR 2012 5.0 S/C- Intermittent No Fuel Warning Issue?
Old Jun 30, 2025 | 07:42 PM
BlackJag90's Avatar
Default Jaguar XFR 2012 5.0 S/C- Intermittent No Fuel Warning Issue?
Hey there,
Back again with more fun times on the new Jag 🤣
So last few drives I've noticed my fuel light/ Low fuel- Gauge shows 0 clearly when I'm at half or even full.
Comes & goes.
Sometimes not at all in an hour drive, othertimes on and off 4-5x per hour drive. Very annoying as it keeps popping a warning on dash everytime it disappears again.
Did some research and got as far as removing the rear seat, cut the circular cut out piece and got to the top of the fuel pump...
Doesn't look horrible, but regardless grabbed some steel wool and cleaned up the connectors prongs. Then inserted plug in and out a bunch of times hoping this might fix 'a dirty connection '.
Haven't test driven it yet to find out, but if this doesn't fix it what would possibly be the next step? -pull pump to check connections within, or is there another prone spot on these cars that tend to cause this dissapearing fuel gauge?
Car is running fine, just annoying orange lights again 😐
Thanks in advance!
Old Jul 1, 2025 | 05:28 AM
kansanbrit's Avatar
More than likely it will be the actual sensor in the tank worn out.
Old Jul 1, 2025 | 09:08 AM
BlackJag90's Avatar
Thanks for the reply!
I have read the black/blue wire plug in the tank (fuel sender wire plug) degrades over time on these cars, maybe worth pulling the pump- maybe direct connecting them with a crimp connection?
Or just replace the whole fuel pump assembly?
Old Jul 1, 2025 | 12:48 PM
BlackJag90's Avatar
Started the car up and almost instantly No Fuel warning came on again after the exterior plug 'cleaning' trick.
So decided to pull the pump/module etc.
Of course I had to fill it to the brim yesterday so it started pouring fuel all under the car, I ran, grabbed some rags and start siphoning about 23 liters.
Pulled the pump, checked all connections fiddled with plugs bunch of times, ran a earth magnet up and down by fuel sender pivot, cleaned the fuel filter and re-installed it.
started the car for a minute to make sure everything is running alright before installing everything.
Tank showed just over half which makes sense after me draining a bunch. No light came on but time will tell- gonna have to take it for a test run... if still not fixed, I'll probably replace the whole unit with an OEM one.
Old Jul 1, 2025 | 03:57 PM
BlackJag90's Avatar
Took it for an hour drive, fuel gauge seems accurate & no more 'Low Fuel' light came on with gauge showing 0 during the entire drive
Hopefully just a dirty connection somewhere & hope it holds up. 🤞
Old Jul 4, 2025 | 09:07 AM
clubairth1's Avatar
Community Influencer
Glad you got it fixed but you have some light burn marks on the pins?
Hopefully yours won't get worse but I have seen major black marks and melted plastic in that plug before.
With the age and miles on the car you "might" have to replace the fuel pump assembly if it gets worse.
2011XFR
Mar 14, 2023 03:24 AM
Turtlepower
Nov 16, 2021 08:23 AM
aholbro1
Apr 13, 2016 01:53 PM
henry k
Jan 11, 2014 08:31 AM
basso
Dec 26, 2012 09:28 AM
