Key can not find after battery change
Old Nov 25, 2024 | 03:57 AM
Allan P's Avatar
Default Key can not find after battery change
Hi I have a 2015 xf that has had its alternator replaced and now it won't start, the battery has been removed. I have heard that you have to remove the key from the car and let all fuse boxes rest for about 30 minutes before working on the car could that be true, now it is about to be replaced modol and new key
Plz help
Regards Allan
Old Nov 25, 2024 | 06:58 AM
clubairth1's Avatar
Community Influencer
Very common problem and you will need to search as there are different causes. Can you get the car hooked up to the Jaguar SDD system?
That's usually required. Forget the resting fuses theory.
Can you tell us what is being replaced and why? Without codes you don't know what your cars problems are. Sometimes you need to reprogram different modules. Others have had to replace CJB (Central Junction Box).
Alternators can cause problems as well. Was your OEM unit rebuilt or is this an after market replacement? Many problems using after market units and it's far better to have your OEM alternator rebuilt. That way you know it's correct for your car.
Finally can you DIY any of this? That is the key to owning a used Jaguar.
Old Nov 25, 2024 | 09:01 AM
Allan P's Avatar
Hi is 2 time is do this first time only change battery and now and after changing the alternator it won't work anymore and body module b doesn't work anymore my question is could it be that the workshop that did it didn't check if there was enough volts on the battery as I can read that could be why it loses the key it must be said that it wasn't the jaguar workshop that did it the car could drive to the workshop but couldn't drive from there and they say it's not their fault i need help
Old Nov 25, 2024 | 11:18 AM
dennis black's Avatar
First go to your trunk and put a multimeter on the battery terminals and tell me the voltage with nothing on all doors and hood closed
Old Nov 25, 2024 | 11:20 AM
voltage
Old Nov 26, 2024 | 08:34 AM
Allan P's Avatar
Is only generator change this time..
so battery was low, but now is body control modul is dead
And work shop say need change
Regards Allan
Old Nov 26, 2024 | 09:28 AM
clubairth1's Avatar
Good suggestion from Dennis but we need numbers? Saying the battery was low is of no help?
After the car has sat all night measure the battery voltage. Then start the car and measure again. This will only be the beginning BUT we must start somewhere?
Armand
E-Pace
Jul 22, 2024 09:08 AM
John316xx
Jun 27, 2022 12:24 PM
jakesdad
Mar 19, 2021 06:48 PM
mchums
Dec 12, 2018 01:41 PM
Watchgeek
Oct 18, 2011 06:17 AM
