Looking to buy
Old Nov 24, 2018 | 03:06 PM
LyferXB9S's Avatar
Default Looking to buy
Morning all, I am in the market for a 2010-2014 jag. Something with the supercharged v6 or one of the v8s. Are there any particular models/years to stay away from and things to pay extra attention to when looking? Here are a few I'm interested in
https://www.facebook.com/marketplace...6080217442318/
https://www.facebook.com/marketplace...4987277180260/
https://www.facebook.com/marketplace...8879159921668/
https://www.facebook.com/marketplace...9226408178636/
Old Nov 25, 2018 | 02:23 PM
Adam J's Avatar
looks like you're open to the entire range of xf or xj models? and you've got a price range of mid teens to high 20k's?
you have a wide range or performance among your links.
all cars require maintenance and depreciate. that's the primary thing to stay away from - cost / unexpected cost. soft wheel alloys lead to needing bend and crack repairs. weak coolant system parts require replacements - either proactively or reactively - your choice - or not.. wheels / brakes / tires are an expense so just understand that before entering in.
if you need AWD, then must go with s/c v6 option for the XF or the XJ. you'll be looking at a newer model in your range or years. 2013 begins the era of the 8 speed transmission, so consider that if comparing a 2012 and older vs a 2013 or newer
older, higher mileage v8 / supercharged v8 vs. newer lower mileage supercharged v6 and newer transmission design / newer infotainment
if you get the high hp models, you;ll be contending with wide rubber band 30 series and 35 series tires to fit the required 20'' wheels to clear the massive brake calipers. the v6 models have smaller running gear with higher profile and narrower tires.
jaguar tax will apply for sure, but so will jaguar smiles - I've had mine for almost 2 years, only drive it occasionally - puts a smile on my face each time and makes me feel special each drive.
Old Jan 9, 2019 | 05:39 PM
erin ellingsworth's Avatar
Default 2010 xf for sale
Hi there, I have a 2010 Jaguar XF with V8. Has leather, moonroof, it’s white. And has 118,000. Good condition. Where are you located
Hello, I have a 2010 xf with V8 118,000. White, leather, moonroof. Where are you located?
bwilson1
Apr 30, 2012 06:34 AM
m4900
30
Jul 11, 2010 08:50 AM
dave5861
Jun 1, 2010 06:35 AM
studioh
Feb 10, 2010 06:17 AM
SMF
Nov 1, 2007 02:29 AM
