Loss of indicator sound
Old Sep 11, 2017 | 05:04 AM
Shislop's Avatar
Default Loss of indicator sound
I have a 2012 Jaguar XF Premium Luxury. The indicator sounds have stopped working - the indicators still work but there is no sound. Jaguar Servicing has quoted $2000 to replace a part where the speaker is located and $1000 to fit the part. To add insult to injury, the extended warranty expired 2 months before the problem started. Does anyone have any suggestions for a less expensive solution?
Old Sep 11, 2017 | 06:26 PM
OzXFR's Avatar
Apparently the speaker electronics are part of the instrument cluster, which is fairly easy to remove, see here: Plea for help - instrument cluster speaker and the thread linked in post #4.
But after that I can't help!
Old Sep 18, 2017 | 04:29 PM
XJL's Avatar
XJL
Was it intermittent before it completely gave out? That's the issue I am having now.
Old Sep 20, 2017 | 05:54 AM
Shislop's Avatar
No, it became very loud and rapid, then stopped altogether.
Old Dec 3, 2017 | 04:54 PM
smgdata's Avatar
Mine was making odd sounds last week, and now nothing its dead.
Old Dec 4, 2017 | 01:50 PM
davetibbs's Avatar
If you can get the instrument cluster out, this part should fit the cluster, it replaces the original speaker which is marked on a spare that I have as "DIGISOUND FB-BMS-3408-01". Looks like it will need to be resoldered but is an easy job - if you can't do it you should be easily able to find someone who can for a lot less than the dealership want.
