Missing Fuses/relays
Old Sep 24, 2019 | 07:18 AM
Projectjags6's Avatar
Default Missing Fuses/relays
Good Morning,
I recently purchased a very high mileage 2011 xf 5.0 Premium as a bit of a project (more on that later) I pulled the engine bay fuse box cover and found this. It seems like there are a lot of empty fuse and relay locations. How do I confirm that A) they are all there B) they are in the correct location? Thanks!!!!
Old Sep 24, 2019 | 07:04 PM
Swilmer52's Avatar
Here goes a few pictures of my fuse box. I have a 2013 5.0 S/C, should be the same. Hope this helps
Old Sep 24, 2019 | 10:29 PM
davetibbs's Avatar
Based on the fact that the fuse locations in my owner's manual aren't even correct for my car, I'd say the question you should be asking yourself is: Is anything not working causing you to believe a fuse or a relay is missing? If not, I'm not sure I see the problem.
Old Sep 25, 2019 | 01:07 AM
lotusespritse's Avatar
If the timing chains haven't been done on a high mileage 2011, I would start there.
Old Sep 25, 2019 | 07:14 AM
Thanks for the pics, that's discouraging that the locations don't seem to match the owner's manual. I'm getting about every warning light possible from abs, vsc, and among others. I believe that it may be to late to do timing chains as I have misfire codes for an entire side of the engine and it does not sounds good at all. I only let it fun for about 3 seconds but I can try and get a video. If it has already jumped timing it's probably toast any ways right?
Old Sep 25, 2019 | 09:55 AM
les's Avatar
les
The very first thing to do when you get a lot of warning lamps and a misfire is to make sure the battery is fully charged.
Old Sep 25, 2019 | 09:58 AM
I did take it out and charge it charged up and held a charge. I know pretty much all modern day cars freak out when the battery is going dead. I just wanted to check the next easiest thing after the battery which to me seemed to be fuses.
alanroberts50
Jul 24, 2018 07:34 PM
Serlock
Oct 12, 2017 09:24 AM
rtcosic
Jun 7, 2017 12:07 PM
Hafrod
May 6, 2016 08:34 PM
mhamilton
Mar 13, 2016 08:01 PM
