Need assist Identification of Wheel Style
Old Oct 7, 2012 | 08:27 AM
jaguny's Avatar
Default Need assist Identification of Wheel Style
2 Pristine 2007 2008 2009 Jaguar XK XJ XF Alloy Wheels 19"x8.5" +41 5x108mm | eBay
Do you know the name of this wheel?
Will it fit '11 XF SC over brakes?
Made in Italy for Jag per listing?
Thank you.
Old Oct 7, 2012 | 12:57 PM
AaronW's Avatar
Believe they are called the Carelia. No idea if they will fit on a S/C someone else will have to chime in...
Accessories Catalogue | Carelia 19"
Old Oct 7, 2012 | 06:55 PM
chXFS's Avatar
The rears might stick out to far. I wouldnt go anymore than 20mm down in offset on the rears. fronts will be fine. Although seeing that they are 8.5 all around that gives you an inch less on the rear, you would probably be ok.
Old Oct 7, 2012 | 09:54 PM
jaguny's Avatar
The Wheel and Tire calcultor from that forum indicates the rears will push out 12.3 mm or just about 1/2 inch. I don't know if these will fit over the brakes though.
H20boy
Dec 24, 2024 03:23 PM
2010 Kyanite XFR
Feb 16, 2016 11:40 AM
1964Daimler
Oct 3, 2015 12:18 PM
Mbourne
Sep 14, 2015 09:21 PM
XJsc-guy
Sep 2, 2015 11:43 AM
