Need help finding the inertia switch
Old Oct 23, 2017 | 02:19 AM
Ebaadremix's Avatar
Default Need help finding the inertia switch
I can’t find the fuel cutoff inertia switch on this jaguar fx sv8 supercharged I’ve looked under all four footrests but I can’t find to seem the switch someone please help. Also am I looking for the right thing? It won’t start up ever since an accident from behind although was very lenient. I hope resetting the switch will solve it right. Someone please help a brother out.
Old Oct 23, 2017 | 03:00 AM
Originally Posted by Ebaadremix
I can’t find the fuel cutoff inertia switch on this jaguar fx sv8 supercharged .....
Welcome to the forum Ebaadremix,
Is this an XF and if so, which year?
Old Oct 23, 2017 | 06:25 AM
Ebaadremix's Avatar
Old Oct 23, 2017 | 08:29 AM
I've searched the Owner's Handbook which only offers the following information on fuel cut-off:
The Workshop Manual gives a little more information. It shows that fuel cut-off is part of the SRS (supplemental restraint system). If this outputs a crash signal on the high speed CAN (controller area network), the ECM de-energizes the fuel pump relay to prevent any further fuel being pumped to the engine.
I cannot find an Inertia Switch in the parts catalogue which suggests such isolation of the fuel supply may set a diagnostic code which has to be cleared rather than restored by resetting the switch fitted to earlier models.
Old Oct 23, 2017 | 09:59 AM
Ebaadremix's Avatar
These are ten of them
When I erase the code it doesn’t allow me to erase the code it says erasing failed it gives me 12 codes atm. I am using g scan 2.
Old Oct 23, 2017 | 10:09 AM
I'd say you should check out the brake switch fault first.
I'm assuming this is an XF so I'll move it over to the tech section.
Old Oct 24, 2017 | 12:38 AM
Ebaadremix's Avatar
I used a battery tester. It says the battery is fine. And after further research it appears you won’t be able to find the inertia switch as unlike other cars it’s not fitted anywhere else but is part of the restraint system. I’ll reoeat the issue. The car won’t start. It’s besn hit from behind very lightly and after that it won’t start. I even checked the brake switch there’s nothing wrong with that. Any ideas what I should move on to checking next? Please help.
Old Oct 24, 2017 | 12:40 AM
Ebaadremix's Avatar
Not only it won’t start it won’t even take a self. Idk if I spelled it right.
Old Oct 24, 2017 | 12:42 AM
Ebaadremix's Avatar
@graham are you there?
Old Oct 24, 2017 | 01:31 AM
Ebaadremix's Avatar
Update - now the key won’t come out as well.
Old Oct 24, 2017 | 01:54 AM
Ebaadremix's Avatar
Default What do you all make of these obd codes and warning lights? Why it won’t taje a self?
O
Old Sep 11, 2019 | 10:45 PM
Lukesh Saluja's Avatar
@Ebaadremix hi ,
how did you manage to solve this problem ,I have a jaguar xf it is behaving exactly same as your car . Please reply me and I will follow the instructions .
Old Sep 12, 2019 | 05:23 AM
sogood's Avatar
Since the car took a rear end hit, could the battery, or any connections have been compromised in any way. I know on the xj6 that I owned, any battery issues would often cause the "Christmas tree" effect which included multiple dash warnings rnings/lights etc. It may also contribute to your non start issue. Just a thought.
Old Apr 9, 2020 | 07:18 AM
Azar's Avatar
Default Jaguar XF 2015
Hi, if anyone can assist me with the common problem after a rear collision.
my Jaguar XF 2015 was hit from the rear, was only a minor damage however as a result the engine wont start now. I will looked at previous forms looks like I’ve got a same or similar issue.
is there any was I can reset the fuel inertia switch on this model without going to Jaguar dealers and paying a fortune.
would appreciate your assistance
many thanks
Az
Old Apr 10, 2020 | 10:41 AM
sogood's Avatar
Default Inertia switch
From memory, the inertia switch is located behind or just above the drivers side kick panel in the foot well. (RHD). It is possible to access it by peeling back the carpet which is made easier by removing the plastic panel. The switch just needs to be pushed in to reset it.
Just realised we're talking about an xf, I had a brain fart and was talking about an XJ (x300). Sorry.
ItalianXtype
Apr 25, 2020 10:54 AM
kev53
Jan 26, 2015 07:28 AM
giandanielxk8
Feb 11, 2014 01:11 PM
wjd03
Mar 31, 2011 10:38 PM
last2letUdwn
Aug 11, 2008 09:27 PM
