Need some Help removing engine junction box
Old Apr 7, 2019 | 02:29 PM
Bullitt1067's Avatar
Default Need some Help removing engine junction box
Hello! New to the Forum and need some help
I have a 2011 XF 5.0. I need to replace the front Strut mounts and Upper front control arms on both sides of the car. I already completed the Driver side but I am running into a small issue on the Passenger side. The Engine Junction Box is covering the nuts/bolts I need to get to. I am going through the workshop manual and it just shows to remove three bolts and set the box aside. Well the box has all the wire running into it and it wont move more than and inch or so. I dont see and harness disconnect either. Any help removing the junction box would be greatly appreciated.
Thank you,
Leo
Old Apr 8, 2019 | 02:13 PM
Bigg Will's Avatar
Its gotta be hung up on something?
Old May 14, 2019 | 12:48 PM
taylorbg's Avatar
Did you ever get this worked out? I am trying to do my control arms as well and had the same issue. Removed the bolts from the junction box and it wouldn't lift more than an inch because of the wiring harness. Also can't figure out how to get to the front bolt of the control arm. Did you give up and take it some where, else any tips?
Old Feb 10, 2020 | 06:01 PM
rockytt's Avatar
I'm in the same boat - bolts removed, but the box only moves an inch or so - anyone figure this one out?
Old Feb 11, 2020 | 07:02 AM
Rummy636's Avatar
You have to manhandle it and either zip tie or bungee it out of the way the best you can. My need a wrench for one of the shock nuts. Don't overthink it. Wont hurt the harness if you pull a little.
Old Feb 11, 2020 | 08:52 AM
rockytt's Avatar
Thanks for the tip - I'll give it a go!
(Actually have to replace the junction box and repair some of the wires underneath)
Abacab
May 9, 2025 02:51 PM
Bullitt1067
Nov 20, 2021 05:42 PM
Abacab
Jul 17, 2016 08:14 PM
sws805
Dec 14, 2012 09:36 PM
patrick12
Jun 1, 2009 05:35 PM
