New jag owner needs help ..2010 xf
Old Mar 21, 2017 | 07:09 PM
BritCars's Avatar
I'd agree with the above. They won't flash an ecu if the car is not working - and this doesn't sound like a software glitch
P0627 says it's the fuel pump relay or connections. See link below. Have your indy check the fuel pump relay, check the wiring harness connectors (that's where I'd start). And the battery as per my post above. I wouldn't replace the pump itself - this suggests it's relay or connections. See below.
http://www.carobdcode.com/p0627-jagu...em-malfunction
Old Mar 21, 2017 | 07:14 PM
Sancho20's Avatar
Ok i will give that a try hopefully that could be it ..thanks
