Oil Change computer reset on 5.0L
Old Apr 16, 2012 | 07:37 PM
Rique's Avatar
Default Oil Change computer reset on 5.0L
Hey folks, I am ready to change my oil on my 5.0L engine. Can I get some instructions on how to reset the computer once job is done. Also, is the drain procedure straight forward. 1. Remove oil pan drain plug, 2. Remove
oil filter house change filter element. 3. Replace and add oil.
Thanks in advance to the certified techs.
Old Apr 18, 2012 | 11:49 AM
Long Islander's Avatar
> Resetting service reminder:
1. Press and hold rear fog lamp switch
2. Turn ignition on, do not start engine
3. Release rear fog lamp switch
4. Press and hold trip button (end of left side stalk)
5. Press and hold rear fog lamp switch
6. See "Resetting Service Light" message in message center
Old Apr 18, 2012 | 12:39 PM
Brutal's Avatar
#7, keep holding till the message says its reset, let go too soon and start again
Old Apr 18, 2012 | 01:20 PM
Rique's Avatar
Thanks fellas preciatit
Old Apr 18, 2012 | 03:39 PM
Jerry S's Avatar
Unless my memory is faulty, I didn't think there was a drain plug on the oil pan for the 5.0 engine; either that or the plug isn't used for draining.
Old Apr 18, 2012 | 06:50 PM
Rique's Avatar
As of a previous thread there is a drain plug that can be re used.
bamforp
Aug 14, 2024 05:36 PM
ZJag
26
Sep 5, 2016 03:33 PM
bdboyle
Sep 4, 2015 06:16 AM
Jag-o-nomic
Sep 4, 2015 03:07 AM
pnwrs2000
Sep 3, 2015 11:55 AM
