Oil level 2010 xf
Old Oct 1, 2020 | 11:03 AM
fredpribyl's Avatar
Default Oil level 2010 xf
Oil level
I cant check my oil it says not available see handbook
Old Oct 1, 2020 | 12:30 PM
Bigv's Avatar
Did you turn on only the ignition and open the bonnet?
Old Oct 1, 2020 | 03:32 PM
pab's Avatar
pab
Yes, you're supposed to fully warm the engine and then shut it off for about 10 minutes. The oil level will then show when you turn on the ignition without starting the engine.
Jaguar: Grace, Pace, and Space - Sir William Lyons
Current: '15 XF (X250) Portfolio AWD 3.0 (it's aubergine)
Past B: '08 S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Past A: '05 X-Type 3.0/AWD Jaguar Racing Green
Old Oct 2, 2020 | 02:25 PM
panels's Avatar
easy trick.
when you are done driving for the day. after shut down, ignition on I think. hit the button on the stalk to check the oil. it will tell you see handbook. shut off ignition and the next morning when you turn on ignition the oil level will show up.
DPK
Apr 20, 2024 08:37 AM
Wguza
Mar 2, 2019 06:08 PM
mghirsch
Oct 17, 2017 07:07 PM
diyjag
Jan 10, 2016 09:02 PM
Maz
Apr 3, 2014 02:39 PM
