P006A 🤦🏽🤦🏽 Help
Old Jun 29, 2024 | 09:07 AM
steveb1471's Avatar
Default P006A 🤦🏽🤦🏽 Help
Hi
was hoping someone might be able to give me some help. For a while now whenever if hit the higher end revs 27500 plus for a period of time I get the dreaded RP red error. After engine ignition cycle the errors is gone and drives fine again until next time i typically hit to motorway
I connected to SDD and no codes, so after much reading on this site i changed fuel filter and air filter. This definitely helped and the RP error dosnt come on quite as fast but it still does. After connecting many time I eventually got a code. It gave me the P006A. Since then I have cleaned the maf sensor with specific cleaner and again no luck.
I have then do a full inspection of all the pipes and found the below
I’ll have took a zoomed out picture too below
I would expect this to be my issue
my question is does anyone know what part this is? Any tips on replacing it and would I be correct in suggesting this is the issue?
its 2013 xf 2.2
thanks
Steve
Old Jun 29, 2024 | 09:17 AM
User 42324's Avatar
Assume this is a diesel & that revs value should read 2750 ?
Old Jun 29, 2024 | 09:19 AM
steveb1471's Avatar
Hi
Thanks for the reply, yes that’s correct
cheers
steve
Gophat
Jan 6, 2023 06:28 AM
jry
Jun 2, 2022 12:30 PM
Jpav27
Apr 17, 2016 02:22 PM
DevSpider
Dec 22, 2014 12:50 PM
