P010C fault code help please
Old Apr 16, 2020 | 08:30 AM
Bill Field's Avatar
Default P010C fault code help please
2008 2.7d xf .fault code help please P010c restricted performance shows on dash when warm and on idle only .Goes away when accellerating
Old Apr 17, 2020 | 07:14 AM
Bill Field's Avatar
Come on someone must know something ??
Old Apr 17, 2020 | 09:22 AM
JagV8's Avatar
Mostly USA people and they typically hate diesel cars.
Old Apr 17, 2020 | 10:16 AM
From the XF (Diesel) Workshop Manual:
There are no extended codes listed for this fault.
Old May 6, 2021 | 02:02 AM
Maxime Lambert's Avatar
Default Jaguar xF
BONJOUR . J'ai exactement le même défaut que toi. À tu trouvé une solution ?
Old May 6, 2021 | 03:42 AM
Bonjour Maxime,
Tous les articles en Anglais s'il vous plaît.
The error code has the following possible causes:
1. an air leak
2. blocked air filter
3. blockage in the induction pipe
4. a harness ground fault
5. a harness power fault
Old May 6, 2021 | 09:57 AM
Oxidizer2k's Avatar
I’m not t a diesel car, but if you have two mass air flow sensors swap them and see if you get a different code. If you have one, you’re mass airflow sensor probably went bad. You could attempt to clean it and see if it works. But usually in my experience it’s done or on it’s way.
i recently got a mass airflow code for B and it went away after I replaced the faulty sensor.
BDuncan
Sep 4, 2021 07:52 AM
Nathanmatthew77
Sep 8, 2018 08:56 AM
Terry Keeling
Jun 30, 2017 10:48 AM
jagman96
Aug 11, 2010 10:35 PM
