Pedestrian system fault
Old Feb 6, 2018 | 02:54 AM
Per's Avatar
Per
Default Pedestrian system fault
Fault code B1200-66, check for frontal damage. Exept I haven't touched anything at all. But I have travelled some atrocious witer roads which are icy and very bumpy. I haven't bottomed the suspension though. When my local specialist tried a readout with autologic the sytem threw up "Too many transient events".
Any pointers to what part of the system is causing this? There are several sensors and of course the "airbags" at the rear corners of the underbonnet area.
Old Feb 6, 2018 | 05:15 AM
I'll guess it's an XF but Model Year would also be a useful addition as your forum Signature.
The PPS (Pedestrian Protection System) is notorious for false warnings on other Jaguar models and was even known to deploy on early XK's without any impact.
If you definitely haven't touched anything, the most likely cause is a failed impact sensing sensor. There are two - left and right behind the front bumper. Relevant Part Number depends on VIN range.
Old Feb 6, 2018 | 08:21 AM
Per's Avatar
Per
The diagnostics said: Too many transients / events. So I think I have a case corresponding to this (XK) TSB as my XF is a MY2008:
TECHNICAL SERVICE BULLETIN
reissue No.JTB00091v2/2008
11 March 2008
Circulate to: Service Manager Parts Manager Warranty Administrator Service Reception Technicians
© Jaguar
All rights reserved.
This reissue replaces all previous versions. Please destroy all previous versions. Only refer to the electronic version of this TSB in GTR.
This bulletin supersedes TSB JTB00091/2008 dated 28 February 2008, which should either be destroyed or clearly marked to show it is no longer valid (e.g. with a line across the page). Only refer to the electronic version of this TSB in GTR.
Subject/Concern: 'Check Pedestrian System' Displayed in the IP
Model:
The New XK - All With Pedestrian Impact System
VIN Range: B00001 Onwards
Markets: All Except NAS
Section: 501-00
Summary
Customer reports permanent message 'Check Pedestrian System' displayed in the instrument pack (IP), with DTC U3000-66 or B1006-92 stored detailing the non-deployment memory in the pedestrian protection module has reached maximum stored events.
This version has been issued for a change in Section from 401 to 501.
Cause: Non-deployment events logging at low speeds and dealers unable to clear DTCs, resulting in module replacement. Suggested Customer Concern Code - S40.
Action: Should a customer express concern, configure the Impact classification system. Follow the Service Instruction outlined below.
Repair procedures are under constant review, and therefore times are subject to change; those quoted here must be taken as guidance only. Always refer to DDW to obtain the latest repair time.
Labor Time
Operation Description Operation No. Time
Configure the Impact classification system 86.99.74 0.2 hours
Repair/Claim Coding
Causal Part: C2P 14924
ACES Condition Code: 42
Service Instruction
1. This procedure requires IDS DVD111 with Patch file 3 loaded or later.
Connect a Midtronic battery conditioner/power supply to the vehicle.
2. Connect IDS to the vehicle and begin a new diagnostic session, by entering the correct VIN for the current vehicle.
3. Follow the IDS prompts to read the vehicle configuration.
4. When prompted 'Do you wish to read diagnostic trouble codes?', select 'NO and then press 'tick' to continue.
5. When the 'Content Model' is displayed select 'Vehicle Configuration' tab.
6. Select 'Module Programming' from the 'Vehicle Configuration' menu.
7. Select from the menu 'Configure existing module'.
8. From the drop down menu select 'Impact classification system'. Press 'tick' to continue.
9. Follow all on-screen instructions to complete this task.
10. When the task is completed, exit the current session.
11. Disconnect IDS and the battery charger/power supply.
Old Feb 12, 2018 | 12:42 AM
Per's Avatar
Per
TSB applied at recent service and all is well.
moar
Jul 31, 2025 01:12 PM
Redescape
Jul 13, 2020 07:59 AM
Michaell
Jan 26, 2015 08:53 AM
jimboire
Oct 26, 2014 02:32 PM
stubbdog
Jun 11, 2014 04:56 AM
