Question: What charger do you use when running full Diagnostics?
Old Apr 28, 2018 | 12:30 AM
kkurulak's Avatar
Default Question: What charger do you use when running full Diagnostics?
Just curious as my old 275/125/60/20/2A use to keep up but now as I lock on 20A it can't keep up and 60A OL after a few minutes at the safety cut-off.
I can't justify getting a Acctiva Pro 70A and just wish to know what is everyone is using.
Kevin
Old Apr 28, 2018 | 07:23 AM
HJ2's Avatar
HJ2
I thought 'idle use' is only 20 Amps?
Old Apr 28, 2018 | 08:54 AM
kkurulak's Avatar
My old charger use to keep the car at 13.4-13.8 on 20A manual mode but now I keep dropping below 12.5 which means the car shuts down half way through diagnosing, I would hate trying to reprogram....
If your referring to the Acctiva Pro 70A, It is programmable to pre-determined amp and final voltage allowing for precise maintaining of current.
A few months...maybe a year (This getting old sucks) I noticed some lab systems that were decent in price and you can maintain up to 17.2 Volts @ around the 20A range by dialing exactly what you wish but can't find them any more.... should have booked marked.
Old Apr 28, 2018 | 05:06 PM
u102768's Avatar
Depends on model year but it should be at least 25 Amps.
Attached Thumbnails Question: What charger do you use when running full Diagnostics?-chargers.jpg
Old Apr 28, 2018 | 07:11 PM
kkurulak's Avatar
Thank you u102768, I see I should have been running at least 50A.
I have been looking at these units;
1. Midtronics (PSC-550S KIT) Power Supply/Battery Charger (As recommended with IDS-SDD-JLR)
2.Fat Boy 75A Variable(12-16V) 110ac
3. Schumacher INC100 100A 12V Battery Charger and Power Supply (Variable 13-14.8V)
4. MST-80+ or 90+
Diddion
Jul 24, 2017 08:14 AM
SouthernGal
Sep 26, 2014 07:58 PM
Thunderbolt 13
Nov 14, 2012 12:04 PM
Simprof
Nov 15, 2010 05:36 PM
