Rear springs ... this can't be good
Old Jun 11, 2024 | 08:55 AM
prolepsis's Avatar
Default Rear springs ... this can't be good
I was inspecting the underside of my 2011 5.0 n/a on Sunday and discovered the condition of the rear springs. Both left and right seem to be failing at the bottom. Is this a common or known failure of these parts?
Old Jun 12, 2024 | 08:17 AM
clubairth1's Avatar
Community Influencer
You did not post where you live??
If in salt area's that would be normal and I don't see anything failing? Do you have a problem with the car?
Are you worried about the black paint peeling and flaking off? Pretty common from what I have seen?
Old Jun 17, 2024 | 10:01 PM
prolepsis's Avatar
@clubairth1 Don't you think that it is more than paint peeling off? Otherwise, it is remarkably thick paint.
Yes, the car has been driven in snow. The last time I measured the ride height it was at or just lower than the lower limit of the tolerance. I'm sure that if I measured now the ride height would be outside of tolerance on all 4 corners. Also, the ride is now quite choppy at slow speeds on anything other than very smooth surfaces.
Old Jun 18, 2024 | 01:14 AM
Bigv's Avatar
It’s definitely paint
Old Jun 18, 2024 | 07:20 AM
clubairth1's Avatar
Yes I would stop worrying as it's completely normal. Have you looked under any other cars?
It's so minor I bet the guys in salt country could post pictures that would make you cry!
Old Jun 19, 2024 | 03:19 PM
lotusespritse's Avatar
It might be more of a sound insulation material. I am working on a Rav4 right now, and it looks like that. It's not paint, but looks and feels like some kind of plastic-y insulation, probably to improve NVH.
Old Jun 20, 2024 | 08:27 AM
prolepsis's Avatar
thanks @clubairth1 @Bigv @lotusespritse
I'll put it on the back burner for now.
Carbon_XJL
Jun 20, 2025 12:38 PM
sportfan
16
Jul 12, 2023 08:07 PM
wrosser2112
Aug 20, 2021 05:24 PM
BlackJack
May 3, 2010 11:12 AM
