Remove the lighting above the sunroof
Old Jun 7, 2017 | 01:03 PM
lyjenny79's Avatar
Default Remove the lighting above the sunroof
Does anyone know how to remove the lighting area where there the Bluetooth mic, sunroof control area is located? I am trying to get to the sunroof bolts.
Step by step or pictures will help.
Old Jun 7, 2017 | 05:35 PM
RonAsonte12's Avatar
find something thin but strong slide it into the end nearest you there are two little tabs holding it up in the front and one on each side but once you get the top two it should fall down theirs nothing to really break so just slide in and poop out
Old Jun 7, 2017 | 05:59 PM
lyjenny79's Avatar
Thank you !! Got it out. The video was so helpful!
Do you know what it means to pull the liner out which will break the clip ? I'm searching for the sunroof mounting bolts.
Old Jun 12, 2017 | 01:01 PM
cyndav6875's Avatar
Default Awesome thanks for video
