reprogram key fob for XF
Old Jun 24, 2014 | 03:28 PM
SexySix6's Avatar
Lightbulb reprogram key fob for XF
please help new owner of 2009 Jaguar XF and I am a female. was only given only
1) fob and dropped it was told by Jag emergency help line to replace battery. when unable to open doors and start car. fob does not work to unlock door. Needs reprogramming. Dealer wants $500.00 to buy another fob then they say it can be reprogrammed.I don"t have this money and not tech savy. Please help! if you can help will in box number. Living in Michigan.
Old Jun 24, 2014 | 05:17 PM
WRXtranceformed's Avatar
Were you able to successfully replace the battery? If not I would try that first, it takes all of 5 minutes to do yourself. If so, is it still not opening the car?
If you really have to get a new key fob, you can buy unprogrammed ones on ebay for $160-$200 shipped. You would just need to get the key laser cut (not as expensive as it sounds, I had it done with my old Lexus) and have it programmed to your car. From some quick research, it does not look like you are able to program it yourself like you can with some vehicles so you will have to take it in to the dealership. Not sure what they would charge you but I would assume something dumb like $100.
Old Jun 25, 2014 | 02:33 AM
I'm not clear on the extent of the damage to the fob or the problem here. Is the fob totally dead?
1. won't unlock/lock the vehicle
2. won't allow the vehicle to start
Or is it just the unlock/lock function that won't work and the only way to enter the vehicle is using the key blade but the vehicle will then start?
Your XF has the same design of fob as my XK and it is definitely dealer (or an independent with dealer level diagnostics) programmable. On earlier Jaguar models the fobs can be programmed by owners but not the current models.
Old Jun 27, 2014 | 05:23 PM
Well, we never heard back so hopefully you aren't still locked out of your car somewhere! :P
philwarner
28
Jul 11, 2017 10:21 AM
redxk8
Sep 30, 2015 08:18 AM
Listers
Sep 30, 2015 07:45 AM
Jzar
Sep 27, 2015 02:55 PM
